About to start my 1st project
Hi All, just joined the forum, and am about to start my first restoration project. I know enough about cars to stumble through this project and come out successfully in the end, but I'll probably be asking a lot of questions throughout the process. I hope you all don't mind. I could put a stock engine together, but don't know anything about tuneing an engine or doing things to it other than putting the stock pieces together, so this first post will start with that.
So, let's begin. I am going to restore a '66 289 (If all goes according to plan this weekend). So, if I recondition the stock engine with a 4V carb, it sounds like I could get 225hp at the tires, right? Edelbrock's power package for the 289 (includes cylinder heads, cam, 4v carb) says it could give almost a 125hp boost. Seems unlikely to me, what do you guys know about that? (also, the complete package is almost 3k, pretty expensive).
What do you recommend I do to this engine as I put it back together? I'm not looking for a beast on wheels, but would like something in the 250-300hp range.
(btw, if I ever wanted a beast, could I just bolt on a supercharger on a 289? or would I need to change the whole block? transmission? drivetrain?)
Thanks in advance for your replys
RE: About to start my 1st project
I cannot tell you a ballpark on a 289. I can run some rough horsepower numbers in DynoSim if you can get me specs on the cam, flow numbers on the heads, and intake CFM.
You can get those numbers out of a 289 without too much problem. But first, you need to check your block. Is it in good or bad condition. What is the mileage? Maybe, think about rebuilding the bottom end while you are tearing into it. Just a suggestion. I do not know nearly as much as most guys on here, but I have asked many a questions, so I know what some of the answeres will be. The edelbrock package, headers, and exhaust will get that car moving.
As others will ask, what are your plans for safety? Upgrading the brakes, suspension, headrests, seatbelts, etc.? 40 year old car doesnt possess the same features as a newer cars.
Plan it all out, think it through on what you want to accomplish, and have FUN!!!
WELCOME TO THE SITE!!!
Thanks guys. Yea, I will recondition the block, and probably replace all the moving components of the engine. In terms of brakes, I was going to do a front disc break conversion, but wasn't planning anything for suspension other than making it stock. What upgrades would you recommend for suspension, mavrick?
Thanks UC, I'll PM you those numbers once I figure out a good combination of parts.
Welcome to the group. Dont worry about asking questions...we all started somewhere with some really dumb ones. Everyone herre is more than willing to offer advice and even s houlder to cry on when you screw something up. Just ask away.
It depends...what are your plans for the car? Restomod or classic? There are many different choices out there, and many members with far more knowledge than myself. But, let me know what your plans are, and I'll try to help.
For the price you will pay for that package and all the parts for the bottom end you can get a 347 crate engine with 400+ hp. If you are considering super charging it later on get forged pistons, forged crank and H beam rods and keep the compresion as low as you can other wise it won't last long.
