crank dampner uhm..
Old 02-02-2008, 11:11 PM
SalikDDD
SalikDDD's Avatar
Default crank dampner uhm..
i got a new crank dampner from summit i'm going to be installing, i have the C4 transmission, tossing back in the old wheel and such, but this dampner came with little weights, am i supposed to add any or what?
SalikDDD is offline
Old 02-02-2008, 11:25 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: crank dampner uhm..
need to make sure you run the 28oz weights if your running the vintage motor or the 50 oz if its a late model motor
rmodel65 is offline
Old 02-02-2008, 11:31 PM
67mustang302
67mustang302's Avatar
And technically it's an absorber, not a dampener. But that's a scientific nomenclature issue. Fluidamprs are the only balancers I'm aware of that actually are dampeners rather than absorbers. And technically the shock absorbers on your car are dampeners, and not absorbers. I think physicists are the only ones that care. And me.
Got a link for the balancer you bought?
67mustang302 is offline
Old 02-03-2008, 12:32 AM
SalikDDD
SalikDDD's Avatar
http://store.summitracing.com/partde...p;autoview=sku
that's the one i bought :|
SalikDDD is offline
Old 02-03-2008, 01:34 AM
valley firearms
valley firearms's Avatar
Your engine is most likely not internally balanced, therefore you should use the 28 oz counter weight. It should bolt on to the back side if I'm not mistaken.
valley firearms is offline
Old 02-03-2008, 01:39 AM
valley firearms
I read this in the installation directions. Unless you want that nice puppy to rust follow the directions and paint it.
svfetter
10-05-2015 11:39 AM
jessicarabbit
09-25-2015 12:41 PM
SteelerNation82
09-16-2015 07:11 AM
EASTIDEE123
09-14-2015 03:52 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: crank dampner uhm..
