Electronic ignition, and advance questions
I have a 1967 289 with what appears to be a single diaphragm distributors that has been converted to electronic ignition (before I bought it) using some Napa kit. I know it still uses the vacuum advance, but I am not sure if it still uses the centrifugal advance or not. So I was just wondering if there was a norm. for these conversions are. All I know is that the vacuum will do a full advance, but does not curve at the higher RPMs, like I thought. Also, when I unplug the vacuum line to the diaphragm there is no advance at all. So I am little lost about whether or not there are some electronic ignition kits that take care of the centrifugal advance with the computer or not.
RE: Electronic ignition, and advance questions
Hiya,
that's the way to test it. just as you mentioned.
unplug vac advance and check on advance timing on idle (let's say it's 8deg before OT)
check again with 2500 revs. If it's still hanging at 8-10 degrees then you don't have a mechanical advance.
If it would be corrected via the electronic module you should see the timing change.
first check if you have a mechanical advance in the distributor.
In the newer ones its sitting directly under the rotor. 2 weights that would move outside when spinning (centrifugal). They are hold back via springs.
If you cannot see that then they might be under the contact braker plate, which will be very hard to get to.
If you're lucky and you can see them, check if you can move them outside manually.
They should move. If they're stuck (rust, springs ....) then this is your problem. try to get them going with a (tiny!!!!) bit of oil.
Kalli
Kalli
If it is the original distributor it definetly has mechanical advance.
Most "performance" distributors are usually ONLY mechanical.
There is no good reason someone would disconnect the weights. The distro is probably gummed up and the top of the shaft, the part with the lobes on it, is not freely moving.
What is the NAPA electronic all about? Part numbers or photos?
Get another distro. Put in a Pertronix or similar electronic ignition, get a Summit Racing brand or MSD multispark CDI and a blaster 2 coil. Finally open your spark gap to 50 mils and your car will thank you.
65Coupester:
as in https://mustangforums.com/m_4568302/tm.htm
let us try figuring out first what's actually wrong ... maybe he's got a great distributor already where the weights are a bit jammed or the springs being to hard ...
ORIGINAL: kalli
65Coupester:
65Coupester:
I think that is the perfect example of what that responsibility post was all about.
Good job, kalli.
ORIGINAL: TexasAxMan
Good job, kalli.
Good job, kalli.
I just can't resist it now....it is so easy
Anyway testing it is really easy and has been described above. But, I am not really sure what the issue you are having is? Are you troubleshooting a problem or is this simply for personal edification?
zanemoseley
09-06-2015 12:58 PM
