C4 or C6
C4 or C6
I have a 71 mustang with a 9 inch rear and i just put in a 351cj I had alot of work done too. I am making around 500 horse power to the rear wheels. I have my old C4 i had in this car with a 302 and I have the C6 that came with the engine, which would be better to build up and use?
RE: C4 or C6
Sorry...I have to ask this question. What have you done to the motor to think you are making 500 to the rear wheels (especially since you haven't even picked out a trans a c6 will have a higher parasidec loss than a c4......so depending on the trans you will have higher or lower RWHP numbers).
To answer directly a 'well built' c4 can work in HP applications in a street car at higher HP levels. A c6 was 'designed' for more power but isn't 'required', however if you are making an honest 580-600+ FWHP I would prefer the beefier c6 just because I hate breaking things
RE: C4 or C6
Ihave had it bored 30 over and i have now stroked it to a 408,I took the stock heads (4v) and did a 3 angle valve job to them as well as ported and polished it, match ported the heads and intake to all my gaskets for improved air flow. I installed a blue printed oil pump and a holley high volume fuel pump. a edlebrock performer intake. A high volume water pump. I replaced the cam with a 280/280 duration i got custom ground for me from comp cams. and of course i balanced and blue printed the hole thing. Oh and i put a 750 thunder on it as well, and for at the moment i have been using the C4 cause i had it rebuilt and put a tran pack on it from B&M and its been holding well but was curious if i should just redo the C6 instead of pulling the C4 and redoing it.
RE: C4 or C6
ORIGINAL: majpain78
I would use the c4 at that power level.
and just to be clear I didn't/don't want to turn your question into a power level debate...I just wanted to make sure I understood where you were at in order to answer your question about which trans
RE: C4 or C6
ORIGINAL: majpain78
so let me get this right the C4 will work if i rebuild it with better parts but if i want something bullet proof build the C6?
If you are making 500 FWHP or less which would be 350-425 ish RWHP I would use a built up c4
