would this fit?
would this fit?
http://orangecounty.craigslist.org/pts/539001509.html
my 65 mustang?
i figured out that the 351 i got for would cost more to fix it than buy a working one.
the one above says its running but it looks like in rough shape.
my 65 mustang?
RE: would this fit?
not unless you want to cut the shock towers...i think to fit the 429 you would need to switch to a mustangII front suspension. so yes it can fit but its probably not worth it if $ is a concern
RE: would this fit?
ORIGINAL: harrisont
yeah i only have like $300. i dont know where all these people on here get running 351s for like $50.
RE: would this fit?
wait a minuite.... u just said you only have 300 bucks and and i6 but you want a v8. you do realize all the money you're gunna spend converting it to a v8 right? (rear end, suspension, brakes, tranny etc.) you have to make the car be able to handle the engine. maybe you know thisand i am just confused lol... if you want to go v8 and you got a i6, you are going to spend a lot more than 300 bucks. i may have mis understood something
RE: would this fit?
Spare yourself the trouble and just get a rebuilt 351 windsor if you would like, i could have picked up one i dont know why i went with a 302 instead of a 351 W http://www.rebuiltautoengines.com/fo...1-engines.html
RE: would this fit?
ORIGINAL: racin66coupe
RE: would this fit?
To do the v8 swap right is about 3 grand start saving up now.Putting a v8 in a inline6 car with out changing everything over is unsafe the front springs will be to weak so it will handle worse brakes are under size for the weight of the car and the 7.5 rear end in it is weak you'll break it with the v8.
RE: would this fit?
ORIGINAL: andrewmp6
