help 66 mustang clutch linkage??
i have a 66 mustang, with a 4 speed top loader, we put a newer block from a 90 mustang in it, changed the timing chain cover, water pump, and oil pan but there is no hole for the knuckle of the clutch linkage, has anyone had this problem? any suggestions would be great thanks/..
RE: help 66 mustang clutch linkage??
You can either convert to a cable or hydraulic clutch or by an adaptor bracket which mounts with the bellhousing bolts if you want to use the stock linkage. Since you switched the timing chain cover and will be using a mechanical fuel pump(?), did you add an eccentric on the cam for the pump?
You may find it cheaper elsewhere, but here is the part you need:
http://www.mustangsunlimited.com/ite...1=TRA670538+01
Good luck!
Jeff
Good luck!
Jeff
I replyed to your other tread that adapter is the only solution other than canging to a t5 and using a cable clutch
https://mustangforums.com/m_4576282/tm.htm
Jskeezy84
09-08-2015 01:40 AM
