speedometer wont work
RE: speedometer wont work
Hi harrisont.
don't think that's it.
the rally pac is a gauge that's made up of tach and clock. when you get one, most of the times the cables have been cut.
That's what a rally pac looks like for a 65 Mustang
http://cgi.ebay.com/ebaymotors/64-1-...spagenameZWDVW
When you say your speedo isn't working anymore, then this most certainly isnt' it.
as jlp66stang says it's most likely a cable (non-electric) that goes from gearbox to speedo. I cannot believe that this cable could snap, but you never know.
if the cable wasn't tightened properly it might just have fallen off. So check your gearbox if theres a hole and a cable not connected next to it. Check the back of your instrument cluster (climb head first where your feet are, look up to the middle of your gauge cluster). There's a thick cable going to the center of it. Is that connected properly ?
If that doesn't help, what year is your car ?
ORIGINAL: stangimgood
harrisont...wow drifting!!!! can you tell me how you have your stang set-up for that? tires? engine/trans mods? thanx
heres a pic of my going sideways. i sometimes drift with no rain but itll just wear out my tires even faster.
so anyone know what the cable is called? i have to by a new one because it literally snapped, it was dangling on the ground when i noticed it. so for now i just slipped it under somewhere so it wont rubbing on the ground.
