distributor help.....
Old 02-07-2008, 12:36 AM
66blownmustang66
66blownmustang66's Avatar
Default distributor help.....
i have a 66 mustang, puta 302 block from a 90 mustang, i set the dist. to top dead center, set it down at numbe rone cylinder. and i have no spark through the coil wire, it acts like it is getting no spark wat so ever, fuel, and everything else is good. i dont know what else it could be.. any help???
66blownmustang66 is offline
Old 02-07-2008, 02:26 AM
az1966
az1966's Avatar
Default RE: distributor help.....
got all the wires hooked up? plugs/coil will fire no matter what,,, are you sure theres no spark/fire in the hole?
az1966 is offline
Old 02-07-2008, 02:34 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
what distributor are you using the classic or the late model?? if you using the classin 1st thing we need to do is makes sure you used the gear off the late model dist other wise the gear will get eaten up. are you getting power to the coil?? i believe the wires pink(have to check the wiring digram for your year)
if your running the late model distributor what are you doing for a brain box??
and also is this tdc on the compression or the exhaust stroke??
rmodel65 is offline
Old 02-07-2008, 05:45 AM
kalli
kalli's Avatar
as you have a separate coil, try first:
connect a plug lead to the coil (the port the usually goes to the distributor).
attach a spark plug to the end of it and hold the thread of the spark plug to a place on the engine where you have ground.(use electrical isolated pliers for that)
have someone start the engine. Check if you get to see a spark jumping
If you can't then:
a) either the coil is dead
b) the coil is not getting power
c) the distributor doesn't switch (for the coild to charge/discharge)
for b) Easiest to check next is if you get full power at the coil:
either with a testlight or with a multimeter (voltage tester) check if you are getting 12V on the + side of coil when key is in ignition position.
for c) if you have a multimeter that tests dwell, hook it up while starting the engine. do you get a reading ?
Kalli
kalli is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
StalkerGT
09-25-2015 02:41 PM
dalehunter
09-25-2015 10:51 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: distributor help.....
