Electric fuel pump, questions....
I am considering putting an electric fuel pump in. I don't have anything installed yet. But my question is if I go with an electric pump, where does it go? Are the fuel lines ran the same? Or do i need a return line to the tank? I know that the spot on the engine where the fuel pump is supposed to go would just be blanked off. I am looking at getting the lines ran and I need to know how to run them if I go electric. I will also need a fuel pressure regulator too right? Other than that, is that all I will need? It will be carburated.
Also,what areany advantages going electricvs. the standard mechanical type?
Thanks in advance for the help.
RE: Electric fuel pump, questions....
I am going to start with your last question, while others will disagree, I see no advantage in using an electric fuel pump over a mechanical pump on a carburated car! I prefer mechanical!
The placement of an electric pump should be close to the tank, as close as practical. Yes you willneed a pressure regulator with most pumps, but you do not need a return line.
Once the pump is removed, a block off plate just goes over the spot where the pump bolts onto the timing cover.
(what I don't like about electrics)
1. Can be noisy
2. need to run wires to back of car
3. additional electric load
4. Not as reliable, more to go wrong.
5. Not as safe, when the engine stops running, (like in an accident) the fuel pump may continue to pump fuel onto the ground unless an inertial safety switch is used.
1. Can be noisy
I didn't really see the need for an electric pump either. I was curious to see if there were any advantages to an electric and I really can't think of any either. Seems like they can be more trouble than they are worth. If anyone else has comments, please feel free.
ORIGINAL: zmetalmilitia
how often do you drive your car? if it sits a couple of weeks at a time an electric pump can fill the carb with gas each time before you crank it. other than that i see no advantage.
The major advantage to an electric fuel pump is reduced likelihood of vapor lock. The electric pump keeps the fuelline pressurized, and since increasing pressure also increases the boiling point of a liquid, you end up with less chance of vapor locking the fuel line.
That said, I completely agree with JMD. There's no real reason to switch away from a mechanical pump on a carbureted car. Too much of a pain for little benefit.
It seems like after reading this thread, the expense involved installing an electric fuel system is too great for the reduced chance of vapor lock. What's the deal with vapor lock, is it a big problem to worry about?
FWIW, you do not necessarily need an external regulator with an electric pump. Check the specs to see the output pressure, e.g. Holley Red does not need a reg, Holley Blue does. The electric has its merits, but like others said, the benefits of it with a carb will probably be outweighed by the cost and installation effort (wiring). Oh yeah, you DO NOT need a fuel pump return line.
Stick to the mechanical, but if you do go electric, I have a Holley Red with about 200 miles on it and an unused Ron Morris Performance mounting bracket.
Good luck!
Jeff
Good luck!
Jeff
