5.0 Into a 1970
Old 02-13-2008, 02:59 PM
Mustangdemon67
Mustangdemon67's Avatar
Default RE: 5.0 Into a 1970
i took down the old pics, the quality was bad. i took some better ones today
the first pic i circled it in red
Mustangdemon67 is offline
Old 02-13-2008, 05:13 PM
jlp66stang
jlp66stang's Avatar
You can use the pulley, bracket and timing cover off you old motor, use the balanceroff the 89. Get a front sump oil pan and plug the existing dipstick hole in the block, use the dipstick in the timing cover and run mechanical fuel pump. Use a 70 water pump and keep the original radiator. If you have the ac bracket for your 70 motor, it will work too.
jlp66stang is offline
Old 02-13-2008, 07:07 PM
70Must
70Must's Avatar
Cool Thanks Guys
70Must is offline
Old 02-13-2008, 07:24 PM
ky
America ftw
ky's Avatar
ORIGINAL: RGH69
Are you certain?There was throttle body injection as early as 1980 on some 302's. 87-93 5.0's were all fuel injected unless I'm mistaken.
everything was CARBED up until 1986. 86 was the last year of 4 eyes and first year of efi. then the last year of 5.0 is 95. this is all common mustang knowledge.
ky is offline
Old 02-13-2008, 08:32 PM
JamesW
Moderator
JamesW's Avatar
Here's some info you may find useful. skip the efi part .
http://www.midnightdsigns.com/Mustang/Engine.htm
JamesW is offline
mustangheaven
01-03-2016 11:20 AM
b8checker
10-08-2015 12:55 PM
mustangheaven
10-07-2015 10:23 AM
b8checker
09-30-2015 07:11 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: 5.0 Into a 1970
