Fixed the Bumper Bracket retainers on the frame rail
As a lot of you know, the nuts on the inside of the frame rails sometimes fall off. Heres my solution of how to repair these. Find a larger nut, clean and enlarge the area to be welded, use a maganet to position the nut behind the rail thru the little hole in the bottom of the rail, weld them in, grind and smooth. As good as new. I was lucky these frame rails were solid.
http://i140.photobucket.com/albums/r...r/mikes082.jpg
http://i140.photobucket.com/albums/r...r/mikes087.jpg
http://i140.photobucket.com/albums/r...r/mikes086.jpg
RE: Fixed the Bumper Bracket retainers on the frame rail
Its on the 65, I have seen a lot of these bad. A lot of people drill thru the rail and use a long bolt only to have the bolts loosen up later. I'm up to 5 hours now.
I'm sure they weretwisted off as they were not there and most likely rusted to the bolts. Thedriversside was OK and they were still usable. I did recover several pieces of metal. The previous owner had ran bolts all the way thru.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
