Dead turn signals
Dead turn signals
Turn signals just died. No warning. Have tried shorting across each fuse with turn signal engaged with no luck, so I know it's not a fuse. Flashers work OK, as do brakes, so I know it's not the wiring or the bulbs. How can I check the switch itself - or is it more likely that it's theblinker can?Probably the original... !!
RE: Dead turn signals
You have a little round turn signal flasher plug-in switch just under the dash (should be on the right side near the ash tray. When it goes south the signals will not flash but all else will still work. Pull it out and replace it and you should be set.
The circuit power comes thru the main flasher (orange and blue wires hooked to it) unit if its dead and the fuses are good it's most likely that flaser. I think you also have a emergency flasher which is a different one that the main turn signals.
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
