TOO BIG OF A CAM?
TOO BIG OF A CAM?
http://www.jegs.com/i/Lunati/638/00093LK/10002/-1
will this work fine in my 351c 2v? im not going to put it in untill i can afford a 2v intake with a 4v carb. but i just want to see if this would be ok on a all stock but intake and headers cleveland.
Adv. Duration: 290°/300°
Gross Lift: .536'/.562'
RPM Range: 2000-6000
RE: TOO BIG OF A CAM?
can someone inform me if this size cam would have any problems. would it work fine on stock 2v heads. only mods with the cam would be around a 650-750 carb and dual plane intake. any suggestions as to how much power a bigger cam such as this adds?
thats awfully big on a stock motor man.. i would go something a little smalleryour not gunna see a ton of difference with such a big lobe seperation.. if you go with a decent size cam you will see more performance than a huge cam...
it will work just check ptv clearance thats the cam they use in this book for the build i was talking about the bracket master 2
you might stop buy booksamillion or barnes and noble and skim through a copy[8D] http://www.amazon.com/Build-Performa.../dp/1884089550
What else are you doing to the car?
Slapping a big cam in an other wise stock car is by far the easiest way to build the text book "man my car is such a dog".
For a large cam like that you need:
Springs (not just lifters)
Non-stock intake
Larger stall converter (if auto)
Non-stock 2.8 gears in the rear
Slightly higher than stock compression
What is the performance goal you are trying to reach? It seems you want a street car, will the use be daily driver? Weekend fun? What is the budget.
What has been recomended about claying is recommended because if you don't take the head of fand confirm a high lift long duration cam will not contact your piston you run the risk of blowing the whole thing up.
Non-stock intake
