door window glass removal
RE: door window glass removal
Take off the little trip on top of the door panel- 2 phillips screws, then take off the arm rest- should be 3 7/16 bolts (mine were anyway), take off the window handle- another phillips screw in the center (possibly under a little sticker), then work on pulling the panel off. It's attached with little clips that fit through holes, you have to pull straight out on them, you may have the outside mirror remote to deal with. Anyway, once you get that off, use the window handle to roll the window down a little till you see the bolts holding the window brackets to the regulator and un-bolt them, more 7/16 bolts. Then the window should slide out either the top or the back.
I was out adjusting mine a couple days ago and that's what mine had to do to get to the glass.
09-25-2015 06:58 PM
