motor mounts
RE: motor mounts
Lakewood Muscle Mounts. They're a stock type rubberized mount, but much heavier duty. That's what I'm using, they work well, a bit tight trying to get the engine in and they still transmit some vibration, but not like solid mounts.
RE: motor mounts
I fought that battle for a while with my old set up.
Make sure your trans mount is new or in good shape.
I took a set of new stock rubber ones drilled a 3/8" hole thru them then ran a nut bolts and washers thru that.
Had to leave a lil slack in for the rubber to work. They worked great and going to re-use them on another car.
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
