T-5 Transmission
T-5 Transmission
I just got my new fron suspension put on and took it to the shop to get it aligned. It felt good driving the car home today, first time in like 2 months! I parked the car outside my house ate some dinner and I was off to the post office to drop off some things. Low in behold the car starts, I tried to put it in riverse and it would not budge?? I put the car in neutral and it went forward???? I put the car in first then second and it would not budge the car would not pull at all?? If I push the clutch in itthe car will roll...other than that the car is in gear all the time? What the heck is going on?
RE: Problem Child!
it sounds like the problem child is closer to the shifter then actually inside the trans.
Does it still feel the same when you try to shift it?
i would start by popping the boot off and then removing the shifter and inspecting the ball/socket area of the shifter. if that checks out it could be a much more serious issue.
