Another "which carb" question
RE: Another "which carb" question
ORIGINAL: my77stang
silver the problem is most of the time driving your running on the front two barrels so your 500 is now a 250. add in a dual plane intake and each cylinder is only drawing from a 125 cfm barrel when its sucking air. this is why you can get away with a slightly larger carb than mathmatically required when using a dual plane intake with a vacuum secondaries carb (which is the combo MOST of us have).
not to mention even ford was using holley 600's on underpowered 302's in a variety of applications for years and years..... that should tell you something.
Kip
vacuum secondaries are not opening in relation to rpm, they open in relation to vacuum in primary booster,
so for that a 600cfm carb with vac secondary should be ok, shouldn't it?
but yes I believe a 500cfm carb should be sufficient as well ?!
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
