Fabbing a restomod dash!
Old 03-22-2008, 12:30 AM
  #31
ninteen66mustang
ninteen66mustang's Avatar
Default RE: Fabbing a restomod dash!
Something you might consider: If i I were in your situation and if fiberglass isnt that expensive, I would practice making other junk first just to get used to it. That way, when you actually do your dash it wont look like poo.
ninteen66mustang is offline
Old 03-22-2008, 04:10 PM
  #32
1970coupe
1970coupe's Avatar
i could practice by building a rear tail panal blackout
1970coupe is offline
Old 03-22-2008, 07:40 PM
  #33
Cruzzar
Cruzzar's Avatar
OOOOOPS. Double Post. Please disregard
You will cut, sand, shape the foam to the almost exact size and shape that you want the finished part to be. The layers of glass will add approximately 1/8 inch. thickness to the foam mold. Be sure to make provisions for attaching it to the dash and areas for the guages to mount to. If the mold has tight compound curves then laying the glass cloth (not matt) will be difficult. You may have to cut the glass in several pieces to get it to form around the curves. If the mold has rather large radiuses you might be able to use just one piece of cloth. When it is cured, you will remove the foam from the backside (if it is not too complex of a shape) leaving a glass form of the desired shape.
Cruzzar is offline
lincolnshibuya
10-06-2015 08:45 AM
Urambo Tauro
10-05-2015 09:37 PM
breaking
10-02-2015 01:27 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
accarter
09-21-2015 11:56 PM
Quick Reply: Fabbing a restomod dash!
