Engine mounting on engine stand
Old 03-23-2008, 04:14 PM
67t5ponycoupe
67t5ponycoupe's Avatar
Default RE: Engine mounting on engine stand
You can get grade 8 bolts at any parts store that has doormand drawers. I would recommend that the engine be lower in the stand. It makes it easier to flip it over to work on the bottom end. To clean up your drive way start with some speedy dry from the parts store.
67t5ponycoupe is offline
Old 03-23-2008, 06:21 PM
65poppy
65poppy's Avatar
Usualy you can tell the bolt grade by the markings on the head of the bolt (six marks = grade 8). Metrics use adifferent marking system than the SAE type markings. For the SAE bolts, here's a chart to help you identify the grade of the bolt.
65poppy is offline
Old 03-23-2008, 10:01 PM
PONYBOY65
PONYBOY65's Avatar
darn it i bought some at my local auto parts store and i guess i have grade 5 bolts[&:]
should i replace them right away for grade 8 or will the 5 handle the job?
PONYBOY65 is offline
Old 03-23-2008, 10:03 PM
67t5ponycoupe
They will be fine
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Roush05
09-10-2015 12:23 PM
Quick Reply: Engine mounting on engine stand
