how screwed am i
how screwed am i
ok first off i am retarded plain and simple.
the 68, 289 has been hesitating lately a lot. off the line the engine would die and then pick up spinning the wheels.
i noticed that when looking in the carb one of the nozzles on the acellerator pump was clogged with something.
most of you can see where this is going. i decided to take the discharge nozzle off with the carb still on the car. (mistake)
i took the nozzle and washers out no problems. soaked them in carb cleaner and the clog was gone. i coated the washers in petroleum jelly to make them stick to the nozzle. the gas will melt the jelly and flow straight through the engine no problem.
i got the nozzle back on everything was perfect. cranked the engine and it sounded like a paint can rattling.
i immediatly shut the engine off and pulled the carb. apparently the brass check needle that is under the discharge nozzle came out and fell into the intake.
so once again, where could it be and how screwed am i.
i have the intake manifold off and cant see it inside the ports. if i spin the engine now with the intake off i cant hear anything abnormal. and the valves move ok.
do i need to pull the heads and look. did i mess up a piston.
damn damn
ok flame away i deserve it
damn damn
RE: how screwed am i
Yep, sh-t happens. Anyway,I don't know of an easy way to get something out of a cylinder without taking the heads off. You definitly don't want to leave it in there, I wouldn't. IMO.
If you dont hear anything and it was small it may be in your muffler now. Tuff call but if all else is working and noise is gone I think id leave it alone.
Brass is soft so shouldnt break or bend the valves or hurt the piston may have melted by now.
That is a tough call,, butthese guys may be right.. If it gets to your consience too much then pull the heads, but if your ok with the thought that it may have been blown out with the exhaust stroke then go with it..
Ouch..
Ouch..
At this point I would just run it,,, but that is just me,I have always been lucky that way
As already stated, if this part is as small as I think it is, it has probably already passed, if not, it will soon pass....
It is kind of like the kid who swallowed a dime,,, it is a little freaky, but this soon will pass... This is a time to be thankful that it was a dime and not a half dollar...
i pulled the right head off and found this
i have never seen this piece on a holley before but it fits the shape of the nozzle hole perfectly. (its a little misshapen so it doesnt fit perfectly) but it still looks like the piece that came out.
i didnt see any other parts but there was some small piecs of smashed brass on top of the piston.
here is the top of the piston as well
[IMG]local://upfiles/40396/FF71260F4CC24CF9847540ACAAB3BB68.jpg[/IMG]
[IMG]local://upfiles/40396/50EC0ED1EEBD431FBD8D204D6BE5E17D.jpg[/IMG]
[IMG]local://upfiles/40396/40B54B7D02CB41229F0E5B279CF28CE0.jpg[/IMG]
