Any suggestions...
Any suggestions...
Well, you got me away from my MOPAR... Now I have a 1970 Mustang Coupe, basicly a blank canvas.. Has no drivetrain, but a solid body. Like I said, I was a Mopar guy.. Everything fit everything.. I would like some suggestions on the Motor and Trans. I do have the 289 and C-4 but would like to start new. Can a 1980's-90's 5.O with AOD be transplanted intomy 1970? Basicly, can I dump the EFI and go carb or should I retain the EFI set up and run the fuel and return lines and wire up a pump. Also will the ECM stand alone.. Man I have some questions for you guys!!Even if I go with a old 302 I would like some overdrive.. So you make the suggestion I'll drop it in! as long as its a clean swap.. I don't weld so good!! Thanks guys.. [align=right][/align]
RE: Any suggestions...
sounds to me from that first post that you want some power but need some economy...daily driver? If thats the case then your 5.0 efi, AOD set up sounds good to me. theres some info in the FAQ or get in touch with JamesW. He has efi engine with 5spd.
If you have the parts the ability to i would keep up the EFI setup. I would love to have that in mine just because of economy and the ability to keep up with the times in terms of better feul management. But, if you wanted to go carb, i have a friend that has a 87 5.0 that he has carbed, all he did was put a 4v intake on the block and it ran up. Well, he may have done more but from what i've heard it seems thats all he did. The transmission he didn't use so i dont know about that.
Lots of parts available for your setup. An AOD will work the same with both. EFI is a little more complicated but with a donor car it's not hard, just time consuming.. I would decide first what direction you would like to go and let us know. There is a lot of people here that have done it already and can help you along.
To start off with, go with the 5.0, all you will really have to change is the oil pan and the pick-up. I would personally go with carb b/c it is much easier to deal with and is DEFINATELY less time consuming to get going. I doubt you would see more power out of FI than a carb if the carb is set up right. But I have done some EFI conversions, mostly on chevys, and they haven't been too bad, just lots of time and lots of checking and double checking. But I would def. go with the AOD if you want mileage. The only disadvantage to them is that they dont handle the power as well as a well built C4. But it doesn't sound like you want 400+ HP to me so you should be fine.
