bolt torque settings
hi all
quick question
can anyone tell me the torque settings for
head bolts
rocker bolts (non roller, hydraulic)
inlet manifold bolts
for a 351C 2v, stock.
I had one guy tell me it doesnt matter for rocker and manifold and 100ft lbs for the head bolts. Just wanna be sure and get them even.
thanks
quick question
head bolts
thanks
RE: bolt torque settings
Let see if this works.
Fastener Type
Torque Spec.
Main cap bots
95-105 ft.-lbs.
Connecting rod bolts
40-45 ft.-lbs
45-50 ft.-lbs
for Boss 351C
Cylinder head bolts (follow factory torque sequence)
105 ft.-lbs.
125 ft.-lbs for
Boss 351C
Rocker arms (non-adjustable)
18-22 ft.-lbs.
5/16" Intake manifold bolts
21-25 ft.-lbs.
3/8" Intake manifold bolts
28-33 ft.-lbs.
Oil pump bolt
25 ft.-lbs.
Cam bolts
40-45 ft.-lbs.
Cam thrust plate bolts
9-12 ft.-lbs.
Harmonic damper bolt
70-90 ft.-lbs.
Flywheel/ flexplate bolts
75-85 ft.-lbs.
Pressure plate bolts
35 ft.-lbs.
Front cover bolts
12-18 ft.-lbs.
Fastener Type
Torque Spec.
Main cap bots
95-105 ft.-lbs.
40-45 ft.-lbs
45-50 ft.-lbs
for Boss 351C
105 ft.-lbs.
125 ft.-lbs for
Boss 351C
18-22 ft.-lbs.
21-25 ft.-lbs.
28-33 ft.-lbs.
Oil pump bolt
25 ft.-lbs.
Cam bolts
40-45 ft.-lbs.
9-12 ft.-lbs.
70-90 ft.-lbs.
75-85 ft.-lbs.
35 ft.-lbs.
Front cover bolts
12-18 ft.-lbs.
Ok that didn't work. Try this link http://www.classictruckshop.com/bt351C_Modified.php
18 -22 for the rocker bolts...would explain why my apprentice (mate) to the novice (me) snapped one off. When I looked at my torque wrench he had it set on 40.[:-]
Thanks 67t5 for the quick response.
true66 if you've got different ideas for rockers and manifold i'd be interested to hear.
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
LivingInThePast
09-16-2015 12:20 PM
