build date on a 65?
build date on a 65?
new forum guy here with a question
we recently bought a 65 to restore, we had a 64 1/2 about 18 years ago and decided to get another one
in a parts catalogue i have it asks on some parts if it was built after 8/17/64 or before 4/15/66 how can i find out this information?
thanks for any help you can give
skip
skip
RE: build date on a 65?
Take the info from your door tag and enter it here http://www.mustangdecoder.com/decoder.html
4/15/66 is very common on engine differentiation I believe. You should check on the engine date as well if you are not certain that the engine is original and you're buying engine parts
you find the date code at the front right on engine when you stand right in front of it. Just where the block ends and head starts. to the right of distributor
here is the results.....
Warranty Number:
Year:
Plant:
F
Dearborn, MI
Body Series:
07
2 Door Hardtop
Engine:
C
289 2v V8
Unit:
762470
762470
Miscellaneous Vehicle Data
Body:
65C
2 Door Hardtop, Standard Bench
Color:
Y
Silver Blue Metallic
Trim:
32
Blue Crinkle Vinyl, Bench Seat
Date:
17T
June 17, 1965
D.S.O:
36
Louisville
Axle:
2.80:1, Conventional
Trans:
C4 Automatic
Warranty Number:
Year:
Plant:
F
Dearborn, MI
Body Series:
07
2 Door Hardtop
Engine:
C
289 2v V8
Unit:
762470
762470
Body:
65C
Color:
Y
Trim:
32
Date:
17T
June 17, 1965
D.S.O:
36
Louisville
Axle:
Trans:
C4 Automatic
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
