Battery issue/advice
My battery died today. It's one of the original-looking Autolite and is only 2.5 years old. My mechanic said he thinks something inside broke.
So, I have a choice -- new similar original battery or a regular battery with an Autolite cover.
I'm leaning toward the latter because (a) it's not a show car and (b) if the new battery dies, it will be a lot easier to replace.
Which would you go with, and why?
RE: Battery issue/advice
"its not a show car"...option 2 ftw
most lead acid type batteries will only last 2 - 3 years anyway and generally on the lower end when they are not daily drivers or used only for short trips.
I cant remember the brand but you have access to a more modern design battery that will last a lot longer. someone will post it[&:]
I called Interstate Battery and told them I needed a Group 24 Top Post battery and they said they have them in stock.
If I go with the cover, I'd wait until I had it, then go to Interstate or Sears with the cover in hand to be sure it fits.
Well, I bought the cover but like ThanksDad, could not find a battery to fit it. Went to 4 places with no luck. Ended up calling and ordering another original for $250 vs. the $50 for the cover. Oh well.
The cover came close to fitting one so the saleswoman suggested I cut into the cover, drill the hole bigger, etc. I then said, "and if it looks like crap after that, I'm now stuck with a fifty-dollar piece of plastic." Her recommendation is I buy a regular battery from them and just take the cut/drilled cover with me and when someone wants to look under the hood, put the cover on. Duh?
logan409
09-26-2015 07:43 PM
