Mechanical vs. Electric Gauges
Old 04-03-2008, 11:05 PM
Toddman0025
Toddman0025's Avatar
Default Mechanical vs. Electric Gauges
I'm looking at Autometer Water Pressure Gauges, cannot decide between mechanical and electrical...
Is one more accurate than the other?
Do mechanical gauges actually push a small amount of fluid to the back of the gauge? (and if yes, how does it not slightly cool before reaching the gauge?)
Thanks for educating this noob
Toddman0025 is offline
Old 04-03-2008, 11:57 PM
Gun Jam
Moderator
Gun Jam's Avatar
Default RE: Mechanical vs. Electric Gauges
Some may disagree but....
I think...
If you want to measure a pressure then Mechanical is without a doubt the best choice for real time accurate measurments (and yes fluid is inside the gauge)
If you want to measure a temperature, or a volume or course a voltage electrical will probably work better and install cleaner.
-Gun
Gun Jam is offline
Old 04-04-2008, 12:08 AM
68EFIvert
68EFIvert's Avatar
I have all electrical gauges. I didn't want to run hot fluid in the car. I know I have a heater so don't give me too much grief. It also seemed easier to install.
68EFIvert is offline
Old 04-04-2008, 12:12 AM
andrewmp6
andrewmp6's Avatar
Most say mechanical read more true but i alway used electrical for one reason what if that line for your oil gauge leaks you get oil all over your carpet or even worse hot oil on your legs.
andrewmp6 is offline
Old 04-04-2008, 12:30 AM
350kmileFord
350kmileFord's Avatar
If everything is run correctly, one wouldn't have to worry about those issues.
350kmileFord is offline
Old 04-04-2008, 12:47 AM
67mustang302
67mustang302's Avatar
I like electrical due to no risk of leaks, but also you can mount the gauge where ever and just wire it up.
67mustang302 is offline
Old 04-04-2008, 12:50 AM
Starfury
Starfury's Avatar
Mechanical temp gauges do not run coolant to the gauge. They're a giant thermometer - they have a temp sender bulb threaded into the coolant and connected to the gauge by a hollow tube filled with a fluid that expands at a constant, known rate (ie. mercury). They're very accurate, usually much more so than electrical gauges. I have one in my 67fb and I like it. The downside is that you can't alter the length of the tube, and it can be difficult to route it.
Starfury is offline
Old 04-04-2008, 07:23 AM
kalli
kalli's Avatar
i personally would go electrical all the way. The only thing I would want mechanical is the speedo.
but that's only my opinion
kalli is offline
Old 04-04-2008, 11:15 AM
JapanGT
JapanGT's Avatar
ORIGINAL: Starfury
And thats why they use them on the Space Shuttle right...................
I used to design detection systems for manufacturers and mining companies. Electrical gauges are no slower
than mechanical, in fact I would say it’s the opposite, unless the gauges are cheap. Personally,
I like the electrical gauges as the wiring is easy to route. Also as an engineer I can tie the signals
into an alarm panel so if anything is out of whack, I don't miss it. Another point isif a gauge needs replacing
there are no leak issues ( oil pressure ). I would stay away from any gauge that uses mercury,
it's toxic and evaporates, so you could be inhaling the stuff each time you drive the car, were it to leak.
But yes, they both do the job, and it's really a matter or personal preference.
Jav
JapanGT is offline
Old 04-04-2008, 11:43 AM
superdavid
superdavid's Avatar
ORIGINAL: JapanGT
ORIGINAL: Starfury
Jav
In modern equipment, I have no doubt that electricalguages are superior to their mechanical counterparts. However, I have both the stock electrical water temp andoil pressureguages and mechanical units installed below my CD player. The mechanical guages are much quicker and have a superior consistency. With the electrical guages I was always kind of wondering if I was on the brink of overheating and stuff, but now I can actually tell whats going on.
superdavid is offline
Quick Reply: Mechanical vs. Electric Gauges
