Locked Rear?
Old 04-06-2008, 11:58 AM
dugan
dugan's Avatar
Default Locked Rear?
OK, way back when, i had my car up on jackstands i started it up and put it in gear and both rear tires were spinning (same speed) does this mean it is a locked rearend?
If it is how much does one of those go for (the whole axle with drum brakes)
After a year of having my mustang i am still new to all of this ughh.
dugan is offline
Old 04-06-2008, 06:02 PM
stanger53
stanger53's Avatar
Default RE: Locked Rear?
Unless the brakes are dragging on one side, having both tires turn like you described doesn't mean anything. This will happen even with a standard open differential.
With the car idling, can you stop one tire by dragging your shoe against it? If so - standard open rear axle.
stanger53 is offline
Old 04-06-2008, 06:43 PM
kalli
kalli's Avatar
be careful doing that.
the better (safer idea) would be to: have it on jackstands in gear, motor off.
then turn one wheel. if the other side rotates the opposite way: open diff. if it turns the same way: not open
kalli is offline
Old 04-06-2008, 06:49 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
if it chirps (outside tire) and clunks going around corners, its locked
if not, its open/posi
FuzzyDiceRule is offline
Old 04-06-2008, 08:30 PM
ninteen66mustang
ninteen66mustang's Avatar
kalli's method is the safest...
Either that, or just do a burnout and see if you get a peg leg
ninteen66mustang is offline
Old 04-06-2008, 09:11 PM
racin66coupe
racin66coupe's Avatar
i like 1966mustang's method the best.
racin66coupe is offline
Old 04-06-2008, 10:39 PM
dugan
dugan's Avatar
OK, i should have gave more details, I KNOW it isn't open cuz i dont get a peg leg..
so i know it is either locked, or posi (ford called it traction loc i think?) but i am not sure which.
dugan is offline
Old 04-06-2008, 10:52 PM
valley firearms
valley firearms's Avatar
or limited slip
[align=left] [/align]
valley firearms is offline
Old 04-06-2008, 10:59 PM
67mustang302
67mustang302's Avatar
Does it chirp/squeel/clunk when you turn?
67mustang302 is offline
Old 04-06-2008, 11:16 PM
FuzzyDiceRule
like i said 4 posts ago?
highly likely its posi, youd know if it was locked
Quick Reply: Locked Rear?
