holes in firewall for after market guages
Thinking of drilling my holes 5/8 or should I not? What can you use to cover the holes, i.e. Rubber boot and make your hole in the boot?I was going to add my mechanicaltemp and oil guages.
Thanks
Thanks
RE: holes in firewall for after market guages
Try to find something similar to these to fit your needs:
http://store.summitracing.com/partde...p;autoview=sku
My mechanical gauges came with firewall grommets. I only used the one for the mechanical temp, though. I ran the oil pressure line through another existing hole (NOT the accelerator linkage hole, heh)
Last time i did this, the hole size had to be big enough for the water temp sender unit bulb and nut to pass thru the firewall. You can get gromets at a good hardware store ( ACE, etc...)
jwog666
12-27-2021 08:09 PM
