C4 Flexplate to engine torque specs....needed
04-10-2008, 08:12 PM
what is the torque specs for a C4 flex plate to crank
66 c4 302
i think i read 80 somewhere i dont know if that is right?
04-11-2008, 06:12 AM
RE: C4 Flexplate to engine torque specs....needed
no one?
04-11-2008, 08:40 AM
I always just put them in and give them a light "bump" with an impact. I have never ever had any problems with them.
04-11-2008, 12:52 PM
Same here. Torqued it once. They backed out a month later.
04-11-2008, 02:47 PM
75 - 85 ft-lbs.Use some teflon pastetype pipe sealant on the threads to keep any oil from leaking out the holes. Tighten the bolts in stages in a criss-cross pattern.
http://www.summitracing.com/streetan...ts_fordtrq.htm
mtgldr
02-03-2024 09:00 PM
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
spamedic
09-09-2015 12:15 AM
vintageaion
09-08-2015 10:45 AM
1965 ,
1994 ,
65 ,
66 ,
c4 ,
crank ,
engine ,
flexplate ,
ford ,
mustang ,
spec ,
specs ,
torque ,
tourque ,
transmission ,
values
