PINK PONY
PINK PONY
HI I AM WORKING ON A 65 COUPE 4 SPEED ON THE PEDAL SUPPORT BRACKET. AFTER REBUILDING IT WITH NEW NEEDLE BEARING KIT I AM HAVING DIFFICULTY GETTING THE ASSY. BACK IN THE CAR . I HAVE ALLREADY TAKEN OF THE STEERING SHAFT COVER AND STILL NO SUCCESS . ANYONE OUT THERE HAVE ANY SUGGESTIONS?[>:]
RE: PINK PONY
If you are adding a clutch cable I know you have to pull the pin drop the pedals, install the bracket assembly, and then reinstall the pedals and the pin...
This might be the best way to do it regardless, cable or not.... Oh, and you will gain a little room by removing the two screws that hold the e-brake to the dash.... (leave the screws in for the e-brake on the firewall, the handle will move a little still.
