Broken valve rocker
Broken valve rocker
68 289 4 bbl, started up, ran fine then noticed some smoke from the right tail pipe. Pulled the plugs andfound the 4 cylinder plug was black. When I took of the right side valve cover found that the Intake vavle (4th cylinder) rocker was broken in three pieces. OK, so I have to replace the rocker. But, will this eliminate the smoke or is there now another issue, leaking valave stem seal?
Thanks,
Thanks,
RE: Broken valve rocker
I would say "yes" to the question of eliminating the smoke. However, this happenned to me once and the reason for the push rod, valve/rocker assembly failure was due to faulty machine shop work on a previous head rebuild. I would suspect that the stud used to mount the rocker assembly is backing out of the head. Make sure you check the dimensions beofre you just replace the failed components.
09-25-2015 06:58 PM
