How Do I Install My HEI Distributor?////vacuum line
Okay, so I got a new HEI distributor for my birthday today, but I have no idea how to install it cuz it didnt come with instructions.
First off, in an article that JMD gave me on how to replace a stock dizzy, it said to disconnect the vacuum lines and then reconnect them, but in the pictures they looked like rubber lines, but mine has a hard bent line (and I think there is only one) as you can see in the pic. How can I reattach that to the HEI? Also, I have no idea where to connect any wires to the HEI, or what wires to use (I assume I use the wires off the coil). All help is greatly appreciated!
Here are some pics:
the dizzy itself
some plug thing...?
vacuum line
coil wires
Here are some pics:
the dizzy itself
some plug thing...?
vacuum line
coil wires
RE: How Do I Install My HEI Distributor?
Okay, I figured out where to connect the power and tach and stuff, but I am still confused about the vacuum line.
I think I am gonna have to cut the hard vacuum line and attach a rubber hose to go from it to the distributor. Will that work?
You shouldn't have any hard vacuum line once you remove your old distributor. Run a rubber line from the vacuum advance on the HEI unit to the ported vacuum port on your carb.
ORIGINAL: Starfury
is that the same thing the vacuum advance hard line is connected to now?
ORIGINAL: ninteen66mustang
is that the same thing the vacuum advance hard line is connected to now? If so, how would I be able to connect a rubber line there cuz the hard line has a bolt type fitting thing...
ORIGINAL: Starfury
Interesting, I don't remember mine having a threaded fitting like that. First thing I'd do is take that fitting off and see what kind of fitting it is. If it's not something you can easily replace with a ****** hose end, you can just cut the line and use it as a nipple for the vacuum line.
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
Man I'd think long and hard before I cut that hard vacuum line. That is an original piece. Fab up your own line and keep the factory piece intact.
