power rack and pinion
Old 10-18-2003, 12:52 AM
midnight65
midnight65's Avatar
Default power rack and pinion
I'm building a '67 mach 1. I've already built an independant rear suspension built from a jaguar raer diff, butt i'm having problems with the front suspension. I've built all the brackets I need for a power rack and pinion. The problem i'm having is that the rack i'm using is out of a late model taurus, but the case is to wide and I don't have much of a turning radius. I need to know if any one knows what rack I can use to fix this problem without having to change or modify any of the brakets i've built. any help would be appreciated.<IMG src=smileys/smiley5.gif border="0">
midnight65 is offline
Old 10-18-2003, 01:40 AM
Jugador1
I ♥ Acer
Jugador1's Avatar
last time i checked machs started in 69...?
Jugador1 is offline
Old 10-18-2003, 02:42 AM
67aquafastback
67aquafastback's Avatar
A 67 Mach 1? Thats new too me. Why in the world would you use a set up out of a taurus. The input shaft angle would be incorrect and the ps lines would be a pain to get in place you would need a totaly differnt steering shaft set up. and the mounts are not desigined for the old style body and its not desigined for a v-8 rear wheel drive. Thats insane to even try.
67aquafastback is offline
Old 10-18-2003, 12:45 PM
midnight65
midnight65's Avatar
sorry it is a 67 fastback with mach 1 stripes. The taurus setup works fine but has crappy turning radius, I have only half the travel I need to turn properly. The input shaft does have a steep angle but that was fixed with a pair of borgeson u-joints and the ps line are no problem. the other concern that I haven't adressed yet is header and clutch linkage clearence but I'm waiting for the oil pan to show up before I can drop the motor back in the car and see where every thing lines up.
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:58 PM
Quick Reply: power rack and pinion
