Gluing quarter skins
#21
RE: Gluing quarter skins
ORIGINAL: rmodel65
its just as strong as a weld and offers more corrosion resistance
As strong or stronger than a weld? Not a chance.
A proper weld will be as strong as the weakest of the base or filler metal. For a quarter panel that will be about 80,000 psi. 3M's own documentation says a max of 3,935 psi in shear. Adhesives work best in shear and 3,935 is good, but peel strength is always a fraction of the shear strength. Take a piece of scotch tape and stick it to a table with some hanging off the end. Now pull on the free end in the direction of the tape. That's shear strength of the adhesive. Now just peel it off perpendicular to the table top. That's peel strength. This shows the difference between peel strength and shear strength of an adhesive. A quarter panel skin is going to be loaded in shear so the adhesive is fine with enough overlap, but other parts of the car have much different loading. This is why 3M even says in their own literature that Automix is for exterior panels only and not for structural members. Quite simply, it isn't strong enough, but a weld is.
Also, longevity of the adhesive joint is dependent on preparation and absence of voids. If there is a void, especially one where moisture can get in, the bond will eventually fail because it will either rust and the rust growth will try to push the two panels apart, or the moisture will freeze in the cold climates with the same result. Remember peel strength?? A void anywhere will create a stress concentration which may or may not be a problem. An adhesively bonded panel that can take a hit a week after a repair is not necessarily the same after 10 or 20 years. Most cars aren't around that long. A welded joint is the same no matter how long after the repair. Particularly a butt welded joint that can be preped and protected on both sides.
For my Mustang, I chose to weld because I want to know for sure it will last.
#23
ORIGINAL: Shawnb23
Some body man told me I should glue my cowl back in... I don't know if I would feel nearly as safe doing that(Since the cowl holds the front clip on basically). But it sounds very nice.. buying a new top and bottom cowl piece and just laying it down and glueing it on.
#24
ORIGINAL: honeygoldcoupe
What's a dual piston gun? Are there two tubes? The Maxim is a single tube with a divider. It's hard to take a photo of but you can see the dark and light sides here.
[IMG]local://upfiles/82474/E4C1D78EE17F447CBB7385355A3053A0.jpg[/IMG]
ORIGINAL: jaw66
Most of the other brands you need a special dual piston gun and yes they all have the dreaded nozzle.
#25
ORIGINAL: rmodel65
different companies use different setups did you use the mixing end on that gun or just mix it together with something?
ORIGINAL: jaw66
#27
ORIGINAL: rmodel65
yes your not supposed to lift just like when installing a windshield. i would just use a metal based filler over the seam.
#28
Can you suggest something? I am not familiar with the metal based fillers. Would that be to minimize moisture intrusion?
ORIGINAL: rmodel65
the alum based filler are the closets thing to leading the surface that you can get. they use fiberglass resin as a hardner instead of the normal filler creme. i normally go for evercoat products and have good results https://www.autobodytoolmart.com/p-12798-15941.aspx
you can get it from local paint stores also
11-10-2015 11:39 AM
wishinsky
09-21-2015 09:48 AM
