JBA Exhaust or HIPO or Hedman
Old 06-07-2008, 11:42 AM
Starfury
Starfury's Avatar
Default RE: JBA Exhaust or HIPO or Hedman
If you can't afford the ceramics now, save until you can. Even the stainless headers will develop a nice rusty finish, and if you're going to spend the money on JBA's, spend it on some that will last.
They should fit just fine on an a/t car. As far as the choke tube goes, you can wrap it around a header tube to try to retain the factory choke (it'll function, but not as well), or you can install an electric or manual choke conversion.
Starfury is offline
Old 06-07-2008, 06:53 PM
Chaos13
Chaos13's Avatar
Hi all,
I am also looking to purchase headers for my 65 coupe. I am planning to put a Smeading 347 in later this year. My question is, do I need to purchase a header for a 302 engine or for a 351 engine? Is the header fitment on a 347 engine different than a 302?
P.S. - I just installed a Steeroids Rack & Pinion...the manufacturers webpage seems to recommend a Headman 88300. I am thinking of going with the Headman 88306 (the ceramic version).
Thanks!!!
Chaos13 is offline
Old 06-08-2008, 09:55 AM
chewy1234
chewy1234's Avatar
If the ceramic are a better way to go the hedman's ceramic are the same price as the stainless steel JBA's. Is the price worth it? I am more concerned about the fit and sealing than the ceramic coating.
chewy1234 is offline
Old 11-16-2013, 11:54 AM
super64
super64's Avatar
I fought with the Mac Long tubes and complete exhaust on my 64 1/2 for over a year. I finally took the Mustang to Bud's Muffler in Denver to have them see what they could do to make things work better. I thought the headers were hitting only the driver's shock tower, but they were also up against my C4 , and several other contact points. Bud's suggested shortys, and told me to shop and order some in and they'd build me a new system around them. That night, I called Summit Racing, and looked at their website while discussing header fit. I chose the Hedman #88406 Coated Shortys. I am so pleased with the fit and even the sound of my car now! I might have lost a little top end, but the car still accelerates like crazy!
super64 is offline
Old 11-19-2013, 01:15 PM
69mach1377
69mach1377's Avatar
Originally Posted by Chaos13
Hi all,
Thanks!!!
302 and no.
69mach1377 is offline
Old 11-19-2013, 03:57 PM
Al Newman
Al Newman's Avatar
Headers are without a doubt the sexy way to go, as evidenced by all of the above responses; however, since you are running an A/T, the HiPo exhausts are cheaper, easier to install, should be installed without gaskets, WON'T LEAK, and won't lose you any noticeable performance. In addition, they won't burn out. I have paid my dues with headers over the years and try to avoid them whenever possible.
Best,
Al
Al Newman is offline
Old 11-20-2013, 04:26 AM
tx65coupe
tx65coupe's Avatar
I have the JBA 1650SJS coated headers on the Mustangs 302, but it has aluminum heads and is a bit of a hot rod. For a stock or near stock engine, I'd go with HiPo manifolds. I just don't see any point to headers on stock engines.
tx65coupe is offline
Old 11-21-2013, 01:05 PM
RC65
RC65's Avatar
I had a pair of Hipo manifolds, so I used them on my coupe. Mild build, so I wasn't looking for anything more. I don't have PS, but A/T, I bought a Hipo H pipe and got a good fit.
RC65 is offline
Old 11-21-2013, 09:03 PM
Gun Jam
Moderator
Gun Jam's Avatar
I have headman ceramic headers and have daily driven them for at least 9 years they still look pretty good.
-Gun
Gun Jam is offline
Dokilar
15
10-16-2015 08:13 PM
09-30-2015 12:39 PM
junior04
09-28-2015 10:53 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
09-24-2015 09:18 PM
Quick Reply: JBA Exhaust or HIPO or Hedman
