Digital Rev Limiter question
Old 05-05-2005, 09:30 AM
Soaring
I ♥ Acer
Soaring's Avatar
Default Digital Rev Limiter question
What is a Rev limiter, and how does it work? What advantage or disadvantage does it create?
Soaring is offline
Old 05-05-2005, 11:44 AM
1970 mach1
1970 mach1's Avatar
Default RE: Digital Rev Limiter question
Hi everyone, I have a rev limiter in the hyfire box. This limiter just keeps me from going pass the blowup point of engine. I have a 4R70W automatic trans with overdrive controlled by a electronic Compushift Control Box, with key pad. This gives me a lower first gear and a overdrive for the highway. The key pad is used to change the hardness of the shift, and the speed of the shift. I have a 430 rear gear which brings me to high rev real fast. I normally just leave it in drive and the box shifts quicker than I can, but if I pull it into low I know that I can't over rev because of the rev limiter will keep me honest. The rev limiter will not let you over spin the engine. This is a very good piece of equipment if you are racing at the 1/4 mile, SCCA, or or any other tracks.
1970 mach1 is offline
Old 05-05-2005, 03:09 PM
Soaring
I ♥ Acer
Soaring's Avatar
OK, so then I will assume I can dial in any max RPM I want. How does it work? In other words, since it is hooked up to the electrical system, how does it limit the max rev?
Soaring is offline
Old 05-05-2005, 03:24 PM
C/Note
I ♥ Acer
C/Note's Avatar
i got a mds dig 6 box many features onit ..
C/Note is offline
Old 05-05-2005, 04:29 PM
1970 mach1
1970 mach1's Avatar
Some rev limiters are also found in the distibutors such as Crane and afew more. Rev limiters function by cutting of the electricial power to the distributor once you reach the max limit that you set. It will cut power till the rpm drops by 200 to 300 rpm some might go to 400 rpm. There are alot of different high rev limiters on the market.
Old 05-05-2005, 04:38 PM
Soaring
I ♥ Acer
Soaring's Avatar
Aha... Thankee Bob. Were you able to post the drag strip video? I haven't seen it yet. You need to have a host first, then give us the URL so we can see it.
Soaring is offline
mtgldr
02-03-2024 09:00 PM
Nick Oliver
10-17-2018 04:22 AM
Lethaldosage423
10-19-2015 12:12 AM
Quick Reply: Digital Rev Limiter question
