Rear end clean up??
RE: Rear end clean up??
I appreciate the info Dave. See it doesn't have the bulge so maybe it is the 8 inch after all. But it's still a very large housing. I must say that it's a good looking underside to the car. I wish mine looked like that. It only needs a coat of paint I guess and some new parts. But thanks again for the info. Thursday I'm going to work on it again if I have the time after work and I'm going to take the tag off and degrease it all to hell so I can hopefully read it.
correct. 289s never came with 9" rears. 9" rears are a bigblock thing
289s all came with 8". and most if not all 6 cylinders had that crappy 7.25" integral piece of ...
if you've seen a 9" housing once you will know the difference between 8" and 9". it just looks bigger.
the 9" are nearly round and the 8" are more oval.
as well all 8" i've seen have tapered axle tubes. means they get smaller circumference towards the end.
My 9" stays 3" dia all the way to axle flange.
check the attachment. I robbed daves pic.
[IMG]local://upfiles/52145/40C60FDA81024622924A4BED13C09C9D.jpg[/IMG]
.... it always seems there is an exception to the rule when dealing with Classic Mustangs. Ford, the dealerships, and the original buyers of these cars seemed to put some weird combinations of options together on these cars. The minute you say that "the 9" rearend did not come behind a 289"... some guy crawls out of nowhere with his C Code '67 w/9" rear and the original dealer invoice showing it was ordered that way.
Personally, I don't rule anything out with these cars. The minute you do, it'll come back and bite you.
Dave
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
