turnsignal indicator light
<TABLE border=0 cellPadding=0 cellSpacing=0 width="100%">
<T>
<TR>
<TD width="100%">Turn signal indicator light on 65</TD>
<TD align=right noWrap vAlign=top> </TD></TR>
<TR>
<TD colSpan=2>
<HR>
</TD></TR>
<TR>
<TD colSpan=2><SPAN class=post>I can't get my 65 notch-back past the safety test in NY because the single lite on the dash indicating that the turn signal is on does not work for the right turn signal - even though the turn signal itself works. That indicator bulb does flash for the left however, so I know the bulb is ok. I think it may be a ground problem, but can't figure out how that circuit works. Unlike the other bulbs in the dash, this one does not seem to have a clear ground connection based on the wiring diagram. It would appear to ground through the opposite turn signal light (i.e. for right signal "on" the ground for the bulb is the left circuit). Is that possible?? Where would you suggest I begin to look for the problem?
</SPAN></TD></TR></T></TABLE>
<T>
<TR>
<TR>
<TD colSpan=2>
<HR>
</TD></TR>
<TR>
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
