lift points for floor jack?!?!?!
Old 09-04-2008, 03:21 PM
1sweet65stang
1sweet65stang's Avatar
Question lift points for floor jack?!?!?!
i know im a mega car newb....im only 16 though so i still have a chance ....i have a 65 mustang and....when i took my car to do stuff i always took it to my uncles garage which has electronic hydrlyic lifts with the two support stands coming out.....well in school im supposed to jack my car up on a floor jack....just need a little bit of help of what i want to jack up onto exactly please help dont need a twisted body or a damaged floor pan :/
1sweet65stang is offline
Old 09-04-2008, 04:50 PM
65rangoon
65rangoon's Avatar
rear end you can just go right on the housing.
for the fronts, theres part of a frame rail directly behind the wheel well that you can use.
65rangoon is offline
Old 09-04-2008, 05:02 PM
1sweet65stang
kk thanks i knew the frame was the obvious choice i knew it wasnt a uni body lolz....just wasnt sure if there were any tips/tricks to the method and if anyone experienced any bad things
Old 09-04-2008, 05:58 PM
65rangoon
65rangoon's Avatar
thats what ive been using on my '65 vert. I tend to put the jack a little further back so that when i put the stand under it its closer to the wheel well then the jack.
rear end just put the stands on the axle housings by the leaf springs
Old 09-04-2008, 07:47 PM
palerider
palerider's Avatar
Have a front cross member that you can put jack on if you want to get both wheels in air same time.
palerider is offline
Old 09-04-2008, 09:29 PM
1slow67
ROTM Moderator
1slow67's Avatar
I used the rear axle and frame rails like the posts above stated.
1slow67 is offline
Old 09-04-2008, 09:32 PM
rlovering
rlovering's Avatar
dude, if that's your car and you are 16.....you are the mother effing man!!!
rlovering is offline
Old 09-04-2008, 09:55 PM
1slow67
ROTM Moderator
1slow67's Avatar
Many of us are around the 15-17 age. I am 16, 1965Fastback is 15.
1slow67 is offline
Old 09-04-2008, 09:59 PM
rlovering
rlovering's Avatar
Ok BA, you are also the man. I would have KILLED for a classic stang as my first car. hello 93 camry instead. meh
Old 09-04-2008, 10:13 PM
65rangoon
65rangoon's Avatar
im not in the teen years although im not that far from it. im only 23, theres some posts in a topic i started with some pictures of the car.
only reason i have the stang though is its been in the family since 1972 and only has 29k original miles and ive liked it and gma wanted it to stay in the family so i bought it.
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
b8checker
09-30-2015 07:11 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: lift points for floor jack?!?!?!
