66 headlights on,..parking lights off?
Old 10-01-2008, 05:32 PM
jamieNerikas66stang
jamieNerikas66stang's Avatar
Default 66 headlights on,..parking lights off?
k just installed headlights and parking lights,...
everything works and turn signals BUT, when i turn the headlights on, the parking lights go off,..
is this correct? or should they stay on
jamieNerikas66stang is offline
Old 10-01-2008, 05:33 PM
racin66coupe
racin66coupe's Avatar
i think there suppoed to stay on..
racin66coupe is offline
Old 10-01-2008, 05:36 PM
MonsterBilly
MonsterBilly's Avatar
deffinatly stay on. check the switch!
MonsterBilly is offline
Old 10-01-2008, 05:41 PM
jamieNerikas66stang
the lighting switch correct?
Old 10-01-2008, 07:56 PM
fakesnakes
fakesnakes's Avatar
Sounds like when you wired the headlight switch you made the classic mistake of connecting the parking/tail lights to the "Park" connection on the headlight switch. When you turn on the parking lights they work fine, but when you turn on the headlights, they go off. If that is the case, move that lead to the "Tail" connection on the headlight switch and it will work correctly.
fakesnakes is offline
Old 10-01-2008, 08:51 PM
mushaus
mushaus's Avatar
On my 66, the parking lights turn off when the headlights come on as well. I'm fairly certain this is the way they are supposed to operate on a 66.
mushaus is offline
Old 10-01-2008, 09:18 PM
DIM67
DIM67's Avatar
Same here on the 67.
DIM67 is offline
Old 10-01-2008, 10:12 PM
Nick.Simonds
Nick.Simonds's Avatar
Same on my 65^^
Nick.Simonds is offline
Old 10-01-2008, 11:04 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah they go off on 0n the early cars
rmodel65 is offline
Old 10-01-2008, 11:18 PM
guybored
guybored's Avatar
My 65 is the same way pull the light **** a little and the parking lights turn on pull it all the way and they turn off and the headlights turn on. If I am not mistaken only the original gt's had the parking lamps stay on when the headlights where on. could be wrong but I read that somewhere.
guybored is offline
Quick Reply: 66 headlights on,..parking lights off?
