My 1967 Mustang stalls when after started. PLEASE HELP!! - Page 2 - MustangForums.com
Old 10-06-2008, 11:27 AM   #11
1slow67
ROTM Moderator
1slow67's Avatar
Not sure how lean. It may also be too rich. When tuning my carb on my 200 it will die if not rich enough. Mine will also die if too rich.
I can get perfect idle then when I get up to where the choke is fully open the car would die because it wasn't rich enough.
I probably shouldn't have put "sounded" in that post.
1slow67 is offline   Reply With Quote
Old 07-29-2013, 03:58 PM   #12
cashbgtp97
I'm watching my buddies car while he's on deployment. It's a 1967 Mustang Coupe (I don't know anything other than that). I'm still learning about it but it was having some problem. I immediately assumed it was just idling too low so I located the throttle line and turned the screw next to it til it stayed on. I've never had an older car w/ a carb, but after reading this thread i assume what i did was opened the carb up more increasing airflow at idle. will this cause further issues or is that a good solution to my problem? the only issue it had was just stalling at idle. does just fine when driving.
hope i didn't threadjack too much! just thought this was similar to the original issue! lol
-cash
cashbgtp97 is offline   Reply With Quote
Old 07-29-2013, 07:52 PM   #13
Gun Jam
Moderator
Gun Jam's Avatar
Nah you didnt Hijack anything this plane is empty...none of the people who replied to this back in 08 are even active members anymore. Next time just start a new thread a not revive one from a decade ago...it really chaps Rmodel's *** when people do that.
unless you had to open the throttle plates a lot its probably no issue. How may turns did it take on the idle screw before it ran okay?
I know on some holley carbs if the idle screw is too far in it will expose the transfer slot and render the idle circuit useless. It will cause problems if this is the case. If this is the case then there a problem causing a low idle issue. Example (low idle secondary to vac leak) but if it runs fine now it should be good!
-Gun
Gun Jam is offline   Reply With Quote
Old 08-04-2013, 10:57 AM   #14
cashbgtp97
sorry for that late response, had to attend a funeral down south.
ya i googled my issue and found this thread, sorry for reviving the dead! lol
i turned it probably about 2 full turns (only turned it about 1/4 a turn each time). it runs fine now.
New Product & Great Price - Diode Dynamics Mustang Taillight Sequencer Module 10-16 tj@steeda Steeda Autosports 0 10-01-2015 10:11 PM
P0148, VERY DESPERATE. Please help. mstahoo SVT Forums 9 08-16-2015 10:12 AM
Dirty Throttle Body? Idle / stalling issues stanngg 2005-2014 Mustangs 10 08-12-2015 04:43 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
Running Lean 01blackgtconv 4.6L (1996-2004 Modular) Mustang 2 08-10-2015 02:25 PM
1965, 1967, 1996, 67, 68, 69, cap, choke, dies, fix, ford, lean, mustang, stalling, stalls, starting
