Martz rear chasis install
Old 03-12-2010, 03:20 PM
  #21
eZ
eZ's Avatar
Yes mine was the same if i remember right we welded 1/8 inch plate on the inside of both frame rails to shim it up.
eZ is offline
Old 03-12-2010, 11:47 PM
  #22
71mach1prochrgd
71mach1prochrgd's Avatar
How big of wheels will urs fit now? Also, if you can find one, a versailles rear axle is like 2 or3 inches narrower. Allowed me to run 10" wheels out back with only slight rub on extreme suspension travel. Also, this setup gives you disc brakes. If you can find grenada fronts, they match and you dont even need to change the proportioning valve. I didnt, but my brake setup is kinda a conglomerate. plus i gotz huge meats out back so more bite on the rear at same brake pressure, but im rambling
71mach1prochrgd is offline
Old 03-13-2010, 07:25 AM
  #23
Slow68
Slow68's Avatar
I'm just running a 94-04 style bullit wheel, 18x10.5, rubber will be about 11 wide, all I will need to do is mini tub to the frame rail. If you wanted to relocate the frame rail you could go as far as you wanted, probably a good 16 inch wide tire until you hit the links. The 94 wheels give me a good offset, looks like I will not even have to narrow my rear end. I don't know what the 9" is from, car should of had a 8" from the factory but it had a 9" when I got it.
Slow68 is offline
Old 03-15-2010, 11:14 PM
  #24
Fostang
Fostang's Avatar
I'm about to start welding mine up.
Fostang is offline
Old 03-15-2010, 11:22 PM
  #25
Fostang
Fostang's Avatar
I wish I could pull up your pics but i guess I don't have enough post on here or something.
Fostang is offline
Old 03-15-2010, 11:24 PM
  #26
Fostang
Fostang's Avatar
could you email me your pics?
efi_67_mustang@hotmail.com
Any tips or pointers?
Fostang is offline
Old 03-17-2010, 07:19 PM
  #27
Slow68
Slow68's Avatar
No tips, pretty straight forward, but I am not done yet, This is what I have done. Like we said, We had to shim the cross member, make sure you are center, I also made sure I was square with the car, You could adjust the links to make the rear end straight, but then you would have launch problems due to different geometry on either side.
Here are almost all my pictures, I did integral subframe connectors that tie into the 4 link.
http://www.cardomain.com/ride/3198601
Slow68 is offline
Old 03-18-2010, 06:11 PM
  #28
musnicki
musnicki's Avatar
Not sure if it's too late but here is a few of mine, might help in some way.
musnicki is offline
Old 03-20-2010, 10:03 AM
  #29
Fostang
Fostang's Avatar
The area I'm more confused about on my martz kit is the shock mount area and where I need to cut etc by the gas tank.
Fostang is offline
Old 03-21-2010, 12:31 PM
  #30
Slow68
Slow68's Avatar
When you get the kit and go to pre fit, it will be clear what you have to do. You measure from the rear of the front brace to install the shock mount bracket, the shock mount bracket has the angles to hug the frame rails but the trunk area by the gas tank is in the way, just have to cut a couple inches of the trunk sheet metal out across the length of the shock mount bar that goes across the trunk area so the cross bar will mount flush with the frame. Then you can build a cap over it, or do what I am going to do and weld the floor to it.
Slow68 is offline
Quick Reply: Martz rear chasis install
