AOD LINKAGE
Old 12-15-2008, 07:06 PM
Norm Peterson
Norm Peterson's Avatar
Try creating an album and uploading them to that. Then you can view whatever picture you want to include in a post from inside the album, copy it, and just paste it into the post as you type it. Really easy if you have the topic open in one window and your album open in a different one.
Norm
Norm Peterson is offline
Old 12-16-2008, 10:50 AM
65Rocky
65Rocky's Avatar
Too funny 66,
As far as the photos I am not seeing how,
65Rocky is offline
Old 12-17-2008, 12:19 AM
71stang99
71stang99's Avatar
I just put my motor and AOD into the car (craigs list buy with no real info on tranny), which way does the shift lever normally go? Mine is pointed straight up. Also how do you make the speedometer gear work with a vintage car (72 mach FMX)? I was told to take off the tail housing to fine the # of teeth and it was a green plastic gear, the input shaft looked like a 4 sided cable. I am trying to compare this to the FMX which if you pull out the cable from the tranny the plastic gear is attached on the outside of the tranny so what do I need to do to get this working? a new cable?, a new gear on the inside of the AOD for the tire/rear gear ratio combination? Also what about the wiring? Do you cut the wires at the shift selector and make a plug to work on the AOD for nuetral and reverse lights? BTW I have purchased the TV cable and Holley adapter so if the shift lever is not normally in the up position does that change the installation for the cable? Sorry for so many quesitons but this my first transmission and engine swap and its close to being done!
thanks
71stang99 is offline
CMcNam
10-30-2022 11:40 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
1stangdown
10-19-2003 10:37 PM
MustangGT95
07-31-2003 02:56 AM
Quick Reply: AOD LINKAGE
