Slow convertible top
Hi: I have a 66 and last summer the top went from real slow to needing help. It goes down great--going back up is the problem. Is this a major problem? Someone told me I just might need it bled. Thanks for your help.
It may be low on hydraulic fluid. It doesn't usually require bleeding unless there is a leak. Often the tubing gets old and cracks. Inspect for leaks, fix any you find and refill. If there are no leaks, your pump may be leaking internally.
LivingInThePast
09-16-2015 12:20 PM
