pinion angle or driveline?
Old 05-01-2009, 04:42 AM
  #241
kalli
kalli's Avatar
ah ... seems that thread is coming to an end ... great news man!
kalli is offline
Old 05-01-2009, 09:58 PM
  #242
Scott H.
Scott H.'s Avatar
Scott H. is offline
Old 05-01-2009, 11:36 PM
  #243
Gun Jam
Moderator
Gun Jam's Avatar
The bushing I have has flutes cut in it so oil can freely flow through it even if its somewhat tight.
Ill see how the new yoke fits into that bushing and check play before I install it on the DS
Thanks
-Gun
Gun Jam is offline
Old 05-02-2009, 04:56 AM
  #244
kalli
kalli's Avatar
I have a feeling if you put on a new yoke with the same short shaft, you might end up in the same situation soon again
I have to check for a bushing in my T5. never seen one ...
kalli is offline
Old 05-04-2009, 05:14 PM
  #245
Gun Jam
Moderator
Gun Jam's Avatar
Okay so the new slip yoke arrived from modern driveline but it wont fit the DS because its a 1310 setup with outside snap rings..
The good news is I just test fit it in the trans to see what it would do and play was reduce quite a bit but maybe not quite to an acceptable level...BUT remember I had to hone out the bushing to get the yoke to fit properly. If the bushing was to be replaced with a new one that wasn't honed out I think play could be eliminated as this yoke fits into the trans with very little effort a new bushing would allow for a snug fit.
At this point I am highly considering abandoning this driveline all together its been nothing but a pain in the *** and a money pit...its like keeping a dying pet or something like that and throwing money at vet fees...Just rack one in the .45 and 50 cents later plus the cost of new dog your set for a long time trouble free. But the stupid half keeps saying "oh just one more 50 dollar operation and he'll be all better...look how much money you have spent so far just 50 more and it will be all fixed".....Ahhh
-Gun
Gun Jam is offline
Old 05-11-2009, 11:02 PM
  #246
phutch11
phutch11's Avatar
Gun - just wondering if you ever got it to work. I haven't posted in a while, but still have my vibration issue. And...oh by the way - the same exact leak issue you describe.
What slipyoke did you end up putting in the tranny? One from a 5.0 or one from an eariler model - i.e. C4 or Toploader?
Good luck..
phutch11 is offline
Old 05-11-2009, 11:37 PM
  #247
Gun Jam
Moderator
Gun Jam's Avatar
Progress is on hold until I can working something out... I have the slipyoke for a t5 with the outside clips it wont fit my DS...
I need to do 1 of 3 things:
1) New DS
2) old style to new style U joint converter (50 bucks)
3) Find new original c4 style slipyoke just like I have now but not worn out
So when I figure out what I should do ill go and do it and let you guys know if it was a stupid idea
Fear not I have not given up yet...Im still at it!!
-Gun
Gun Jam is offline
Old 05-12-2009, 05:29 AM
  #248
kalli
kalli's Avatar
Hiya,
kinda of a PITA you got a T5 slipyoke as Dennys driveshafts supply the whole lot.
I don't want to recommend to get a u-joint as well and then you figure: hell that's doesn't work either and then end up buying a DS.
(is what I'm doing. replace all parts and then decide to get the full lot proper .... :s )
but the bright side is you'll get a u-joint for 25$ not 50$
Give us the following info and I can point you to the correct U-joint
U-joint Axis in driveshaft:
cup diameter: 1", 1-1/16" or 1-1/8" ? (1.0, 1.063, 1.125")
inside our outside snapring?
if inside snaprings measure from snapring to snapring as well as total length of axis
if outside snapring, measure total length (is probably 3-1/4")
U-joint Axis in Yoke:
cup diameter: 1", 1-1/16" or 1-1/8" ? (1.0, 1.063, 1.125"). In this case what's the diameter of the hole?
if outside snapring, measure from snapring to snapring (probably 3-1/4" as well)
Kalli
kalli is offline
Old 05-12-2009, 10:15 AM
  #249
Gun Jam
Moderator
Gun Jam's Avatar
are you saying that denny's has the old style yoke?
Gun Jam is offline
Old 05-12-2009, 10:24 AM
  #250
kalli
kalli's Avatar
no idea what they have. as far as I know they just match the splinecount so you have the full lot from start to finish
Kalli
kalli is offline
Quick Reply: pinion angle or driveline?
