pinion angle or driveline?
Old 06-17-2014, 09:53 AM
  #311
69mach1377
69mach1377's Avatar
There is only 1/8" clearance now, but moving the whole engine/trans back would place the shifter body better in the existing cutout and allow the back of the T5 to be elevated a bit more. Either that, or do some surgery to the hump.
69mach1377 is offline
Old 06-17-2014, 11:09 AM
  #312
barnett468
barnett468's Avatar
hello. . ok even if you lower the pinion you still cant raise your trans enough to get the shaft to run downhill by even 3 degrees if your measurements are accurate . you would also need to lower the ngine. .. they have mounts for doing this but the exhaust may need to be modified . . .kinda a nightmare. . can you post a photo of the angles at trans and pinion?
barnett468 is offline
Old 06-17-2014, 10:56 PM
  #313
Gun Jam
Moderator
Gun Jam's Avatar
I feel for ya buddy...this sounds real familiar...I hope you get it dialed in.
Gun Jam is offline
Old 06-30-2014, 10:18 AM
  #314
69mach1377
69mach1377's Avatar
Yup...painful. So I took some measurements to see what changed between the FMX and T5 mounting.
On the trannys themselves; the distance from the shaft centerline to mounting pad is within 1/16", so no big deal there.
On the crossmembers; the T5 mount is dropped about 3/4" compared to the FMX, so that is the culprit. But this is only about 1.2 degrees, not anywhere close to what I would need ideally.
I used to get vibes way over 100 mph, so it was not an issue. But at 80 it is a no go.
Old 06-30-2014, 12:27 PM
  #315
barnett468
barnett468's Avatar
hello . . so if you even could raise your trans .750 at the mount your driveshaft would still run uphill exiting the trans?
Old 06-30-2014, 01:02 PM
  #316
69mach1377
69mach1377's Avatar
It appears so and that was how it had been since 1989 when I bought it. Now 25 years later, the FMX to T5 swap exposed this issue.
Old 06-30-2014, 03:42 PM
  #317
barnett468
barnett468's Avatar
wow, that is a bummer. i already mentioned the only things that i can think of that can cause that. how about buying a different car, lol.
Old 06-30-2014, 04:15 PM
  #318
69mach1377
69mach1377's Avatar
A new gt500 would do...
Old 06-30-2014, 04:23 PM
  #319
barnett468
barnett468's Avatar
you might want to check the driveshaft angle first just to be safe, lol.
Old 07-15-2014, 03:26 PM
  #320
Gun Jam
Moderator
Gun Jam's Avatar
super relevant!
-Gun
Gun Jam is offline
Quick Reply: pinion angle or driveline?
