Door lock rods vibrate like crazy
As the title says... Both the driver and passenger side rods vibrate and make a lot of noise when I'm driving down the road. Has anyone else ran into this issue? Thoughts? Solution?
Have they always done this? Have you recently worked on the doors or the locks that could cause this? Maybe try and see why they are so loose and it may be a simple fix. If all looks ok, try and wrap the rods with something where they are hitting to try and dampen the noise. Typically, they shouldn't be that loose.
I have these things in there and don't have the problem.
http://mustangsunlimited.com/itemdy00.asp?T1=F2136+01
Yea I saw something similar for my yea (66)
I have Stainless inserts but I guess these clip inside the stainless inserts?:
http://mustangsunlimited.com/itemdy00.asp?T1=114N+01
or
http://mustangsunlimited.com/itemdy00.asp?T1=F2464+01
And can someone tell me why I can purchase 1 for 9 bucks or 2 for 3 bucks?
And now I'm confused. Is my standard interior supposed to have the stainless inserts or should my doors have plastic-only inserts?
or
or
or
