Looking to start a T5 conversion
302 motors prior to 1982 (or 1984..I forget) have a flywheel that has a 28oz imbalance. Later model 5.0 motors have a 50oz imbalance. So to run a late model flywheel on an early motor, you have to either find an aftermarket flywheel that is designed for this transition, or you take a late model flywheel to an engine shop and have them cut it down to the early model 28oz imbalance.
The pic below shows a late model flywheel cut down to use on an early motor.
Alright I think I get what you are saying for the flywheels, basically get the 50oz to weigh 28oz. But what is the difference between the two other than the weight? I don't see a real difference in the picture.
And thanks Gun for the measurements to aim for. I definitely was not going to cut anything on the drive shaft before fitting it and seeing how much needs to go. The cut once measure twice method.
they have different pressure plate bolt patterns and run different size clutches. The late model centrifical clutch is much smoother.
Not sure but I believe the ring diameter is slightly different.
I used the King Cobra clutch M-7560-C302N with the 50.oz flywheel M-6375-C302.
Pressure plate bolts and dowel pins kit M-6397-A302.
Bell housing M-6392-R58.
Modern driveline clutch kit.
I don't remember what I did for pilot, throwout bearing and fork...
Just reuse the parts from the fox donor car.
I put a lot of miles on this application with a 342 stroker and nothing ever faded or broke down.
I'm running a Tremec not a T5, so you might have to reuse the fox bell housing.
The R58 bell I'm using, allows for the old style starter as well and it even fit behind a Cleveland. Not that it's gonna help you, lol.
Alright thanks. So I'm am going to try to get everything I can from the fox, I'm going to get the t5 bellhousing and hopefully get the fork, pilot and throwout bearing. So at this point I will need;
50oz flywheel machined to 28oz
Modern Clutch
Clutch Linkage kit from whoever
Transmission crossmember
Adapter yoke & U joint
Anything else I need?
What about the pressure plate?
Modern Clutch
WARNING READ...
This whole "shorten your DS about an inch" business might just be the cause of me wasting lots of time and some money on pinon angles and such.
Im not sure yet but the DS yoke might be hanging out from the trans tail shaft too far because I had it shorted 1 inch so it would fit with out binding. I followed someones advice when they said "ah about an inch and your good to go"
And here I am chasing my tail fighting pinion angles when it might be the DS is too short...
Im thinking that "oh about an inch" needs to be rephrasied to: you need to measure the distance from the face of the tail shaft housing where the oil seal fits to the face of the DS yoke. the gap between the two must be greater than 0.468 but no larger than 0.689.
Im begining to think this "about an inch" business costed me about 350 dollars and coutning....extra.
keep that in mind.
-Gun
keep that in mind.
-Gun
Here is what I did to measure my freeplay:
Jacked up the rear end and put jack stands under the axle to support the full weight of the rear end to simulate the natural position of the car.
Unbolted DS from the 3rd member.
Slid the yoke all the way into the T5.
Measured the distance from the U joint and its mounting surface on the 3rd member. I measured a gap of .5 inches.
Is this the distance you are referring to?
Where did you get the greater than 0.468 but no larger than 0.689 distance from?
I am not sure of the forces that will cause the gap to decrease such as full compression of the springs, full launch acceleration or braking and how they move the DS.
The last thing I want is to have all of the free play go away and break a u joint or bend the DS or worse...
Thoughts???
Thanks
Ron
I was using those numbers as examples to make a point that "about an inch" is far to subjective for something that quite possible could be more critical than initially thought.
Here is a photo of my actual setup using real numbers..
Thats the end result from someone say "hey bout an inch shorter"
The distance that read 1.77 is the one I'm referring to.. I my case if I think if the DS was perfect the 1.77 gap should realistically be between 0.980 and 1.255 inch
Again this might not even the problem...and maybe "about an inch" is indeed a good enough and entire issue really is just pinion angle.
Im just trying to help you guys out by suggesting that you should shoot for a real number or real range of numbers I honestly think that this real range of numbers is .980 to 1.255" would be excellent. ..to be safe if it turns out that a subjective fake number isn't accurate enough.
Good luck
-Gun
Good luck
-Gun
actually every mustang is different as far as I can tell. When doing the swap you can NEVER assume that your DS must be made shorter. Sometimes they are fine as they are sometimes they need to be .750 shorter sometimes over an 1" shorter.
The only way to know how much to trim off it is to physically measure it once its all ready to go.
-Gun
-Gun
