71-73 Guages
71-73 Guages
I have a 73 mach 1 that originally came with a standard gauge package with idiot lights and no tach, the car came with a nice gauge package from a 71 mach 1 including the center console gauges and tach I’m trying to find out for certain that I can perform the job with the right plug and a little solder. I’ve heard so many things from parts vendors who don’t know anything about what there selling, that I thought I should ask someone who knows something about mustangs what I need to know is A) is it possible and B) where do I get what I need. It seems like everything on these cars is impossible to find.
RE: 71-73 Guages
Well I’m capable of doing all the wiring I know that a lot of it is just color matching sand soldering, and I know how to run a Tach wire, but I’m having a hard time picturing how to wire the center console gauges, and I still don’t have the plug I need to do the swap out anyway. Painless Wiring pointed me to a company called M&H who specializes in OEM wiring so hopefully that wont be a problem.
RE: 71-73 Guages
so your recomending replaceing the entire wiring harness, i guess back to the fuse block, I havent traced the wires that far back, but i think thats what your telling me. I still havent contacted M&H Ive had like an hout between getting up and going to work, way too much partying, and not enought working on the car. Im gonna try to give em a call tomarrow.
RE: 71-73 Guages
I have a 73 Mustang with the entire gauge package and tach stock.
I would tell you to go ahead and replace all of your wiring. My tach is intermittent and I have had to rewire the connector for the voltage regulator. Go ahead and do it once right. This winter I am probably going to replace all of my wiring with painless.
If you have specific questions, let me know. I have messed with all of the wiring.
RE: 71-73 Guages
Ok, I still havent been able to find either just the plug or the harness could you point me in the right direction on that. Would I be able to find somthing like that at a swap meet or somthin, cause i have extra parts i need to get rid of.
Dearborn5.0
08-09-2004 10:42 AM
