They are not that complicated pieces of equipment. You can easily build your own. I built one out of some scrap metal. Its nothing fancy but it was free.
from stangtjk's picture, it would be almost the same thing to use 2 engine stand that swivel with a very little bit of cutting and welding, incase you don't have a massive supply of scrap metal...
I happen to have a massive supply of scrap metal I didn't use any plans, like I said there is not much to it. Just get 2 pieces of pipe that fit into each other without much play, cap one end of the smaller diameter pipe so it doesn't slide out, weld the outer pipe to a post with a couple legs on it. Then just make a piece to mount the car to it and your done. I threw mine together in an hour or two.
mine took roughly 3 days to complete. most of which was figuring out what I wanted. Mine is over built but it has NO flex like I have seen on some of the professional models. I think that the only thing i would have done differently is to mount the back to the shock mounts so I can work on the rear pannel.
I agree with Joe67, acutual time could be much longer. I would like to take my time with this part of the restoration. I will look into building one, looks fun.
