cigarette lighter and radio '67
Old 02-17-2009, 12:09 PM
rossifumi21
rossifumi21's Avatar
Question cigarette lighter and radio '67
When my boyfriend and I bought the Mustang there was no cigarette lighter in it. We bought a new one but can someone tell us with what kind of wire do we have to connect it ( colour?). And we allso bought a new radio/cd player because there wasn't one in it. And we have the same problem, which wires do we have to use to connect it.
rossifumi21 is offline
Old 02-17-2009, 12:26 PM
rst08tierney
rst08tierney's Avatar
What type of shape is the Wire Harness in? Has it been tampered with and cut into by the P.O? If it is, wire color will not help.
Do you have basic knowledge on how to use a voltage meeter?
rst08tierney is offline
Old 02-17-2009, 01:12 PM
MIL1ION
MIL1ION's Avatar
Just above the ashtray you should see a solitary female 90* bullet connector dangling from the main harness
that just slides on to the back post of the lighter.
Here is the radio connection.
Note: the stock radio grounds though the chassis of the radio,
Blue/red stripe wire is for the bulb inside the radio.
The black with yellow stripe wire is for POWER and can be used as a KEYED power source for your deck.
The RED wire with inline fuse on it can go to the above connection or in behind the cluster there is a YELLOW 3-way connector with 2 or 3 bullet connector holes
This image is from a Ford Truck but the connector still looks like this on your car.
The Yellow MEMORY wire will require an ALWAYS HOT connection. Usually people splice into the cigar lighter wire.
Numerous people don't have clue about wiring and seem to hook them up wrong and blow fuses
http://hammar.dyndns.org/~djhamma/wi...67/67radio.jpg
How else can I help you ?
MIL1ION is offline
Old 02-17-2009, 01:42 PM
rossifumi21
My boyfriend his dad knows much about electricity and knows how to use a voltage meeter.
Old 02-17-2009, 02:23 PM
MIL1ION
MIL1ION's Avatar
If you follow my directions you won't need it.
Perhaps you can reply to everyone that replies to your posts ?
MIL1ION is offline
baddog671
07-26-2016 01:20 PM
kevsgt
10-09-2015 10:12 PM
breaking
10-02-2015 01:27 PM
unit91
09-15-2015 09:53 AM
wenmill
09-11-2015 07:07 AM
Quick Reply: cigarette lighter and radio '67
